Ir para o conteúdo principal
Dell Inspiron 3542 Heat Sink Replacement
O que você precisa
  1. Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: passo 1, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: passo 1, imagem 2 %32
    • Slide the latches on both sides of the computer outward to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Inspiron 3542 Heat Sink Replacement: passo 2, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 2, imagem 2 %32
    • Remove the screw. (1x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inspiron 3542 Heat Sink Replacement: passo 3, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 3, imagem 2 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 3, imagem 3 %32
    • Remove the screw. (1 x m2 x 3mm)
    • Move the hard drive to the open area and remove it.
  4. Dell Inspiron 3542 Heat Sink Replacement: passo 4, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 4, imagem 2 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 4, imagem 3 %32
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the screw. (1 x M2 x 3mm)
    • Remove the wireless card from the laptop.
  5. Dell Inspiron 3542 Heat Sink Replacement: passo 5, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 5, imagem 2 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 5, imagem 3 %32
    • Turn over the laptop and open it.
    • Use the plastic prying device to release the keyboard.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
    • Remove the screws. (3 x M2.5 x 5mm)
  6. Dell Inspiron 3542 Heat Sink Replacement: passo 6, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 6, imagem 2 %32
    • Unplug the touch pad cables located on the palm rest.
  7. Dell Inspiron 3542 Heat Sink Replacement: passo 7, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 7, imagem 2 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 7, imagem 3 %32
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  8. Dell Inspiron 3542 Heat Sink Replacement: passo 8, imagem 1 %32
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  9. Dell Inspiron 3542 Heat Sink Replacement: passo 9, imagem 1 %32
    • Loosen the cables on the antenna.
  10. Dell Inspiron 3542 Heat Sink Replacement: passo 10, imagem 1 %32
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  11. Dell Inspiron 3542 Heat Sink Replacement: passo 11, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 11, imagem 2 %32
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  12. Dell Inspiron 3542 Heat Sink Replacement: passo 12, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 12, imagem 2 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 12, imagem 3 %32
    • Unplug the cable on the bottom part of the mother board.
    • Remove the motherboard from the laptop.
  13. Dell Inspiron 3542 Heat Sink Replacement: passo 13, imagem 1 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 13, imagem 2 %32 Dell Inspiron 3542 Heat Sink Replacement: passo 13, imagem 3 %32
    • Turn over the motherboard.
    • Unplug the cooling fan.
    • Loosen the 3 screws from the heat sink.
    • Remove the heat sink.
Conclusão
4 outras pessoas executaram este guia.
Rachel lindsey
Membro desde: 03/21/17
733 Reputação
Autoria de 5 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 47
Ao todo: 1,535
