Ir para o conteúdo principal
Dell Inspiron 3520 Screen Replacement
O que você precisa
  1. Dell Inspiron 3520 Screen Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 3520 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Screen Replacement: passo 2, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 2, imagem 2 %32 Dell Inspiron 3520 Screen Replacement: passo 2, imagem 3 %32
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Screen Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 3520 Screen Replacement, Keyboard: passo 3, imagem 2 %32
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Screen Replacement: passo 4, imagem 1 %32
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Screen Replacement: passo 5, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 5, imagem 2 %32
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 Screen Replacement, Screen: passo 6, imagem 1 %32 Dell Inspiron 3520 Screen Replacement, Screen: passo 6, imagem 2 %32 Dell Inspiron 3520 Screen Replacement, Screen: passo 6, imagem 3 %32
    • Locate and remove the 14 (5mm) Phillips #00 screws from the bottom of the laptop.
    • Locate and remove the two 5mm Phillips #00 screws found under the keyboard.
    • Disconnect the two controlling wires with the blue pull tabs.
  7. Dell Inspiron 3520 Screen Replacement: passo 7, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 7, imagem 2 %32 Dell Inspiron 3520 Screen Replacement: passo 7, imagem 3 %32
    • Using the spudger, carefully work your way around the edge of the upper shell.
    • Lift the upper shell away from the laptop.
    • Close the laptop and remove the casing over the hinge using the spudger.
  8. Dell Inspiron 3520 Screen Replacement: passo 8, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 8, imagem 2 %32 Dell Inspiron 3520 Screen Replacement: passo 8, imagem 3 %32
    • Gently pull the cable located near the fan free from its dock.
    • Just behind the optical drive locate the 4mm Phillps #00 mounting screw for the small circuit board and remove it.
    • The board should then pull free.
    • Take note of how the cables fit along the ridge for when it comes to reassembly.
  9. Dell Inspiron 3520 Screen Replacement: passo 9, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 9, imagem 2 %32
    • Open the laptop and locate the two hinges.
    • Each hinge has two 5mm Phillips #00 screws that need to be removed.
    • With the screws removed the screen should pull free.
Conclusão
5 outras pessoas executaram este guia.
Ian
Membro desde: 01/30/15
1.557 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-2, Watkins Winter 2015 Membro de USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
Membros da 3
Autoria de 5 guias
Um comentário
These instructions are not for screen replacement
Ryan Zulu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 17
Últimos 30 dias: 50
Duração total: 5,818
