Ir para o conteúdo principal
Dell Inspiron 3520 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 3520 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 3520 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 3520 Keyboard Replacement: passo 2, imagem 2 %32 Dell Inspiron 3520 Keyboard Replacement: passo 2, imagem 3 %32
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 3520 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Keyboard Replacement: passo 4, imagem 1 %32
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Keyboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 3520 Keyboard Replacement: passo 5, imagem 2 %32
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
Conclusão
7 outras pessoas executaram este guia.
Ian
Membro desde: 01/30/15
1.557 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-2, Watkins Winter 2015 Membro de USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
Membros da 3
Autoria de 5 guias
Um comentário
Hi, any ideas why a NEW keyboard still wouldn't work after installing it? The ribbon was connected properly, it’s the right keyboard, and I made sure the driver was updated. Any help would be greatly appreciated. Started a new job and my keyboard went to $@$* in the first week. Can’t really afford to buy a new laptop this weekend. It works with an external USB keyboard so it’s probably not a software issue… I think?
Alittle advice would be greatly appreciated. Thanks!
Stumpedu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 40
Duração total: 6,379
