Ir para o conteúdo principal
Dell Inspiron 3148 WLAN Card Replacement
O que você precisa
  1. Dell Inspiron 3148 WLAN Card Replacement, Back Panel: passo 1, imagem 1 %32 Dell Inspiron 3148 WLAN Card Replacement, Back Panel: passo 1, imagem 2 %32
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 WLAN Card Replacement: passo 2, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 WLAN Card Replacement: passo 3, imagem 1 %32 Dell Inspiron 3148 WLAN Card Replacement: passo 3, imagem 2 %32
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: passo 4, imagem 1 %32 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: passo 4, imagem 2 %32 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: passo 4, imagem 3 %32
    • Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
    • Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
    • The card should pop right up once the screw is removed.
  5. Dell Inspiron 3148 WLAN Card Replacement: passo 5, imagem 1 %32
    • Remove the two wires by pulling them upward, away from the WLAN card.
  6. Dell Inspiron 3148 WLAN Card Replacement: passo 6, imagem 1 %32 Dell Inspiron 3148 WLAN Card Replacement: passo 6, imagem 2 %32
    • Using your fingers, pull the WLAN card up and away from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Christopher Gravelle
Membro desde: 10/23/18
837 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Membro de UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 287
