Ir para o conteúdo principal
Dell Inspiron 3148 RAM Replacement
O que você precisa
  1. Dell Inspiron 3148 RAM Replacement, Back Panel: passo 1, imagem 1 %32 Dell Inspiron 3148 RAM Replacement, Back Panel: passo 1, imagem 2 %32
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 RAM Replacement: passo 2, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 RAM Replacement: passo 3, imagem 1 %32 Dell Inspiron 3148 RAM Replacement: passo 3, imagem 2 %32
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 RAM Replacement, RAM: passo 4, imagem 1 %32
    • Locate the RAM chips on the motherboard.
  5. Dell Inspiron 3148 RAM Replacement: passo 5, imagem 1 %32
    • There are two tabs on either side of the RAM chip. Pull them away from the chip.
  6. Dell Inspiron 3148 RAM Replacement: passo 6, imagem 1 %32 Dell Inspiron 3148 RAM Replacement: passo 6, imagem 2 %32
    • The RAM chip will pop up out of the slot.
    • Pinch the RAM between two fingers, making minimal contact. Gently pull away from its port.
    • Remove the RAM from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Membro de UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 295
