Ir para o conteúdo principal
Dell Inspiron 3148 Battery Replacement
O que você precisa
  1. Dell Inspiron 3148 Battery Replacement, Back Panel: passo 1, imagem 1 %32 Dell Inspiron 3148 Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Battery Replacement: passo 2, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 3148 Battery Replacement: passo 3, imagem 2 %32
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
  5. Dell Inspiron 3148 Battery Replacement: passo 5, imagem 1 %32
    • Using the iFixit opening tools, lift the battery out of its housing.
  6. Dell Inspiron 3148 Battery Replacement: passo 6, imagem 1 %32
    • Once loosened, use your fingers to lift the battery up and out of its housing.
    • There is a small cable which sits in a rut in the top of the battery. Ensure that it is pushed out of the way before removing completely.
  7. Dell Inspiron 3148 Battery Replacement: passo 7, imagem 1 %32
    • Remove the battery completely.
Conclusão
Equipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Membro de UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
Membros da 3
Autoria de 7 guias
Um comentário
Apparently the battery screws on mine all have red thread lock on them, meaning they will not come out and I fear I may end up stripping them if I’m not careful, I got one out, which his how I know they used red thread lock. Blue would have been sufficient
Joshua Vignolo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 276
