Introdução
This guide will walk you through replacing your Dell Inspiron 17R-N7110 keyboard. You will be using a metal jimmy to pry up the edges of the keyboard, which may require some force and result in some popping sounds. Care should be used during this process, but be aware that some force is okay and even necessary for this replacement.
O que você precisa
Place the laptop on a flat surface with the Dell logo upside down.
Flip the laptop over. The battery will be in the top center.
Flip over and open your device. Gently wedge the metal Jimmy into the rightmost hole at a 45-degree angle. Make sure that the Jimmy is between the silver metal portion of the keyboard and the silver plastic edge around the keyboard.
Tilt the metal jimmy away from you to pry up the edge of the keyboard.
Repeat the previous actions on each of the other three holes to release the keyboard.
Uma outra pessoa concluiu este guia.
