Ir para o conteúdo principal
Dell Inspiron 17R-N7010 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 17R-N7010 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
  2. Dell Inspiron 17R-N7010 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
  3. Dell Inspiron 17R-N7010 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove both screws that connect the keyboard to the laptop chassis.
  4. Dell Inspiron 17R-N7010 Keyboard Replacement: passo 4, imagem 1 %32
    • Look for the four locks that secure the keyboard on top.
    • Push the lock into the case with a plastic opening tool. It is important to note that each lock has a spring behind it
    • Lift the keyboard up a little bit. A plastic opening tool or nylon spudger can help in lifting the keyboard.
  5. Dell Inspiron 17R-N7010 Keyboard Replacement: passo 5, imagem 1 %32
    • Lift the top side of the keyboard up and place it upside down. This enables you to access the keyboard cable, which is connected to the motherboard.
    • Lift up the left side of the brown tab with your fingernail and it will open up at 90-degree angle. This will unlock the connector.
    • Unplug the keyboard connector from the motherboard.
    • Remove the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 1,302
