Ir para o conteúdo principal
Dell Inspiron 17R-5737 Motherboard Replacement
O que você precisa
  1. Dell Inspiron 17R-5737 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Motherboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 17R-5737 Motherboard Replacement: passo 2, imagem 2 %32
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Motherboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 17R-5737 Motherboard Replacement: passo 3, imagem 2 %32
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
  4. Dell Inspiron 17R-5737 Motherboard Replacement, Optical Drive: passo 4, imagem 1 %32 Dell Inspiron 17R-5737 Motherboard Replacement, Optical Drive: passo 4, imagem 2 %32
    • Remove one 4.8mm screw with a JIS #00 screwdriver.
    • Remove the optical drive.
  5. Dell Inspiron 17R-5737 Motherboard Replacement, Access Panel: passo 5, imagem 1 %32
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
  6. Dell Inspiron 17R-5737 Motherboard Replacement, Hard Drive: passo 6, imagem 1 %32 Dell Inspiron 17R-5737 Motherboard Replacement, Hard Drive: passo 6, imagem 2 %32 Dell Inspiron 17R-5737 Motherboard Replacement, Hard Drive: passo 6, imagem 3 %32
    • Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver.
    • Slide the hard drive to the left.
    • Slide the hard drive to the right and up.
  7. Dell Inspiron 17R-5737 Motherboard Replacement, RAM: passo 7, imagem 1 %32 Dell Inspiron 17R-5737 Motherboard Replacement, RAM: passo 7, imagem 2 %32
    • Slide the two clips away from the RAM.
    • Lift the RAM out.
  8. Dell Inspiron 17R-5737 Motherboard Replacement, Keyboard: passo 8, imagem 1 %32
    • A metal spudger can scratch delicate internal parts. Be extra careful when removing the keyboard.
    • Use a metal spudger to loosen the main frame of the keyboard.
    • A metal spudger should be used instead of a plastic one because a plastic one will probably break.
    • Make sure to get the spudger under the entire keyboard and not just under the keys.
  9. Dell Inspiron 17R-5737 Motherboard Replacement: passo 9, imagem 1 %32 Dell Inspiron 17R-5737 Motherboard Replacement: passo 9, imagem 2 %32 Dell Inspiron 17R-5737 Motherboard Replacement: passo 9, imagem 3 %32
    • Slowly lift the keyboard.
    • Lift the locking flap that holds the ribbon cable in place.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap.
    • Remove the keyboard.
  10. Dell Inspiron 17R-5737 Motherboard Replacement, Palmrest: passo 10, imagem 1 %32 Dell Inspiron 17R-5737 Motherboard Replacement, Palmrest: passo 10, imagem 2 %32 Dell Inspiron 17R-5737 Motherboard Replacement, Palmrest: passo 10, imagem 3 %32
    • Remove two 1.6mm screws from beneath the optical drive with a JIS #00 screwdriver.
    • Remove the nine remaining 4.8mm screws from the back of the computer with a JIS #00 screwdriver.
  11. Dell Inspiron 17R-5737 Motherboard Replacement: passo 11, imagem 1 %32 Dell Inspiron 17R-5737 Motherboard Replacement: passo 11, imagem 2 %32 Dell Inspiron 17R-5737 Motherboard Replacement: passo 11, imagem 3 %32
    • Remove the two exposed ribbon cables.
    • Remove the palmrest.
  12. Dell Inspiron 17R-5737 Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Remove the Wi-Fi chip by pulling upwards.
  13. Dell Inspiron 17R-5737 Motherboard Replacement: passo 13, imagem 1 %32 Dell Inspiron 17R-5737 Motherboard Replacement: passo 13, imagem 2 %32 Dell Inspiron 17R-5737 Motherboard Replacement: passo 13, imagem 3 %32
    • Remove six 4.8mm screws with a JIS #00 screwdriver.
    • Remove two 3.2mm screws with aJIS #00 screwdriver.
    • Disconnect three cables from the front of the motherboard.
    • Slowly lift the motherboard exposing the bottom side.
    • Remove the ribbon cable from the back of the motherboard.
    • Remove the motherboard.
Conclusão
David Callahan
Membro desde: 10/19/17
559 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G7, Bailey Fall 2017
UMASSD-BAILEY-F17S3G7
3 Membros
Autoria de 11 guias
1Comentário do guia
Hello Frends... Sry I speak not perfect English and come FROM ÖSTERREICH,
I give my best and PLEASE help when you are a Profi!?
Can someone please help me which FASTEST CPU I can make.
I have the Dell Core I5-4200U installed.
Which pedestal do I have?
Have the Dell Inspiron 17R-5737 laptop and have now installed 2 times 8 GB of memory.
But during a test I get that I can not install Windows 11Pro because my CPU is too slow.
Is this now a 5737 socket or no idea.
Please help me friends
I would be incredibly grateful to you.
Mfg
Bacher Johann
Johann Bacher (Blacknet) - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 2,166
