Ir para o conteúdo principal
Dell Inspiron 17R-5737 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 17R-5737 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 17R-5737 Keyboard Replacement: passo 2, imagem 2 %32
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 17R-5737 Keyboard Replacement: passo 3, imagem 2 %32
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
  4. Dell Inspiron 17R-5737 Keyboard Replacement, Optical Drive: passo 4, imagem 1 %32 Dell Inspiron 17R-5737 Keyboard Replacement, Optical Drive: passo 4, imagem 2 %32
    • Remove one 4.8mm screw with a JIS #00 screwdriver.
    • Remove the optical drive.
  5. Dell Inspiron 17R-5737 Keyboard Replacement, Access Panel: passo 5, imagem 1 %32
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
  6. Dell Inspiron 17R-5737 Keyboard Replacement, Hard Drive: passo 6, imagem 1 %32 Dell Inspiron 17R-5737 Keyboard Replacement, Hard Drive: passo 6, imagem 2 %32 Dell Inspiron 17R-5737 Keyboard Replacement, Hard Drive: passo 6, imagem 3 %32
    • Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver.
    • Slide the hard drive to the left.
    • Slide the hard drive to the right and up.
  7. Dell Inspiron 17R-5737 Keyboard Replacement, RAM: passo 7, imagem 1 %32 Dell Inspiron 17R-5737 Keyboard Replacement, RAM: passo 7, imagem 2 %32
    • Slide the two clips away from the RAM.
    • Lift the RAM out.
  8. Dell Inspiron 17R-5737 Keyboard Replacement, Keyboard: passo 8, imagem 1 %32
    • A metal spudger can scratch delicate internal parts. Be extra careful when removing the keyboard.
    • Use a metal spudger to loosen the main frame of the keyboard.
    • A metal spudger should be used instead of a plastic one because a plastic one will probably break.
    • Make sure to get the spudger under the entire keyboard and not just under the keys.
  9. Dell Inspiron 17R-5737 Keyboard Replacement: passo 9, imagem 1 %32 Dell Inspiron 17R-5737 Keyboard Replacement: passo 9, imagem 2 %32 Dell Inspiron 17R-5737 Keyboard Replacement: passo 9, imagem 3 %32
    • Slowly lift the keyboard.
    • Lift the locking flap that holds the ribbon cable in place.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap.
    • Remove the keyboard.
Conclusão
David Callahan
Membro desde: 10/19/17
559 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G7, Bailey Fall 2017
UMASSD-BAILEY-F17S3G7
3 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 634
