Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Integral to establishing internet connection, the WLAN card happens to be the final dismantling step before one can access the motherboard.
  1. Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case. This may take some effort to accomplish.
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
    • Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
    • These two captive screws will loosen but will not separate from the panel.
  4. Using a spudger, pry into the gap in the plastic revealed by loosening the screws.
    • Using a spudger, pry into the gap in the plastic revealed by loosening the screws.
    • Lift off the access panel.
  5. Using a Phillips #000 screwdriver, remove the three 5 mm screws securing the hard drive to the laptop.
    • Using a Phillips #000 screwdriver, remove the three 5 mm screws securing the hard drive to the laptop.
  6. Grabbing from the left of the hard drive, slide the part to the left and pull up, lifting it away from the machine.
    • Grabbing from the left of the hard drive, slide the part to the left and pull up, lifting it away from the machine.
  7. Using your fingers, separate the metal tabs located on the left and right of each stick of RAM by pulling them apart from each other.
    • Using your fingers, separate the metal tabs located on the left and right of each stick of RAM by pulling them apart from each other.
  8. Pull each RAM stick out of the machine, separating each piece from its respective slot.
    • Pull each RAM stick out of the machine, separating each piece from its respective slot.
  9. Open the laptop to reveal the keyboard.
    • Open the laptop to reveal the keyboard.
    • Using a plastic opening tool, pry the keyboard free from the palmrest assembly at the plastic tabs located across the top of the keyboard.
  10. Once free from the palmrest, flip over the keyboard.
    • Once free from the palmrest, flip over the keyboard.
    • Unplug the ribbon cable connecting the keyboard to the motherboard.
    • Remove the keyboard.
  11. On the bottom of the laptop, use the Phillips screwdriver to remove nine total 5 mm screws from the following locations:
    • On the bottom of the laptop, use the Phillips screwdriver to remove nine total 5 mm screws from the following locations:
    • Four screws at each corner of the laptop’s bottom panel
    • Two screws within the battery slot
    • One screw to the left of the hard drive
    • Two screws located below the RAM
  12. Using your fingers, unplug the two palmrest ribbon cables found at the bottom left of the integrated keyboard’s slot.
    • Using your fingers, unplug the two palmrest ribbon cables found at the bottom left of the integrated keyboard’s slot.
  13. Use the metal spudger at the bottom-right corner of the palmrest’s faceplate to pry underneath the plastic casing and separate the palmrest from the laptop’s bottom plastic shell.
    • Use the metal spudger at the bottom-right corner of the palmrest’s faceplate to pry underneath the plastic casing and separate the palmrest from the laptop’s bottom plastic shell.
    • Once the spudger has leverage between the two halves of the case, work the tool around the right, bottom, and left edges of the palmrest, prying the top from the bottom at around every half-inch.
    • Lift off the palmrest assembly.
  14. Disconnect the two antenna cables connected to the WLAN card.
    • Disconnect the two antenna cables connected to the WLAN card.
  15. Use the Phillips screwdriver to remove the single 3 mm screw securing the WLAN card to the laptop.
    • Use the Phillips screwdriver to remove the single 3 mm screw securing the WLAN card to the laptop.
    • Remove the WLAN card.
Conclusão
Thomas Griffin
Membro desde: 21/03/2019
840 Reputação
9 Guias de autoria
Equipe
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 87
