Introdução
Follow this guide if your disk drive is damaged and needs replacement.
O que você precisa
Place the laptop on a flat stable surface.
Flip the laptop over so the underside is visible.
Remove the 2mm Phillips #00 screw next to the module cover.
Pull the disc drive away from the laptop.
4 outras pessoas executaram este guia.
