Introdução
Follow this guide if your disk drive is damaged and needs replacement.
Peças
Não são necessárias peças.
  1. Unplug the laptop before changing the battery to avoid electric shock. Place the laptop on a flat stable surface.
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Locate the battery lock switch. Slide the lock switch to the left (away from the lock symbol).
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  4. Remove the 2mm Phillips #00 screw next to the module cover. Pull the disc drive away from the laptop.
    • Remove the 2mm Phillips #00 screw next to the module cover.
    • Pull the disc drive away from the laptop.
Conclusão
3 outras pessoas concluíram este guia.
Tina Rickard
711 reputação
5 Guides authored
Equipe
Cal Poly, Team 6-3, Forte Spring 2014 Membro de Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Membros
7 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 686
