Ir para o conteúdo principal
Dell Inspiron 1721 DVD Drive Replacement
O que você precisa
  1. Dell Inspiron 1721 DVD Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 1721 DVD Drive Replacement, Battery: passo 1, imagem 2 %32
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: passo 2, imagem 1 %32 Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: passo 2, imagem 2 %32 Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: passo 2, imagem 3 %32
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 DVD Drive Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 1721 DVD Drive Replacement, Keyboard: passo 3, imagem 2 %32 Dell Inspiron 1721 DVD Drive Replacement, Keyboard: passo 3, imagem 3 %32
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 DVD Drive Replacement, Back Cover: passo 4, imagem 1 %32
    • Disconnect the touch pad connector.
  5. Dell Inspiron 1721 DVD Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron 1721 DVD Drive Replacement: passo 5, imagem 2 %32 Dell Inspiron 1721 DVD Drive Replacement: passo 5, imagem 3 %32
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
  6. Dell Inspiron 1721 DVD Drive Replacement, DVD Drive: passo 6, imagem 1 %32 Dell Inspiron 1721 DVD Drive Replacement, DVD Drive: passo 6, imagem 2 %32
    • Grab the DVD drive and pull straight out from the side of the case to remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 164
