Ir para o conteúdo principal
Dell Inspiron 1721 CPU Fan Replacement
O que você precisa
  1. Dell Inspiron 1721 CPU Fan Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 1721 CPU Fan Replacement, Battery: passo 1, imagem 2 %32
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 CPU Fan Replacement, Hinge Plate Cover: passo 2, imagem 1 %32 Dell Inspiron 1721 CPU Fan Replacement, Hinge Plate Cover: passo 2, imagem 2 %32 Dell Inspiron 1721 CPU Fan Replacement, Hinge Plate Cover: passo 2, imagem 3 %32
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 CPU Fan Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 1721 CPU Fan Replacement, Keyboard: passo 3, imagem 2 %32 Dell Inspiron 1721 CPU Fan Replacement, Keyboard: passo 3, imagem 3 %32
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 CPU Fan Replacement, Back Cover: passo 4, imagem 1 %32
    • Disconnect the touch pad connector.
  5. Dell Inspiron 1721 CPU Fan Replacement: passo 5, imagem 1 %32 Dell Inspiron 1721 CPU Fan Replacement: passo 5, imagem 2 %32 Dell Inspiron 1721 CPU Fan Replacement: passo 5, imagem 3 %32
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
  6. Dell Inspiron 1721 CPU Fan Replacement, Heat Sink: passo 6, imagem 1 %32 Dell Inspiron 1721 CPU Fan Replacement, Heat Sink: passo 6, imagem 2 %32 Dell Inspiron 1721 CPU Fan Replacement, Heat Sink: passo 6, imagem 3 %32
    • Unscrew the Phillips #0 screws attaching the heat sink to the motherboard.
    • The screws attaching the heat sink to the motherboard are part of the heat sink.
    • Carefully remove the heat sink from the motherboard.
    • You may have to apply upward force while removing the heat sink from the motherboard, due to the thermal paste between it and the CPU.
  7. Dell Inspiron 1721 CPU Fan Replacement, CPU Fan: passo 7, imagem 1 %32 Dell Inspiron 1721 CPU Fan Replacement, CPU Fan: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the fan power cable from the motherboard using a pair of tweezers.
  8. Dell Inspiron 1721 CPU Fan Replacement: passo 8, imagem 1 %32 Dell Inspiron 1721 CPU Fan Replacement: passo 8, imagem 2 %32 Dell Inspiron 1721 CPU Fan Replacement: passo 8, imagem 3 %32
    • Remove four 3mm Phillips #1 screws.
    • Gently remove the fan from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 214
