Ir para o conteúdo principal
Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement
O que você precisa
  1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: passo 1, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: passo 1, imagem 2 %32
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 2, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 2, imagem 2 %32
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 3, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 3, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 3, imagem 3 %32
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 4, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 4, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 4, imagem 3 %32
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: passo 5, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: passo 5, imagem 2 %32
    • Gently remove the I/O cable.
  6. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 6, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 6, imagem 2 %32
    • Remove the fan cable from the motherboard.
  7. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 7, imagem 1 %32
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  8. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 8, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 8, imagem 2 %32
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
  9. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: passo 9, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: passo 9, imagem 2 %32
    • Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
  10. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 10, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 10, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: passo 10, imagem 3 %32
    • Lift the heatsink off the motherboard.
Conclusão
Delia Padilla
Membro desde: 08/23/22
588 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 1-3, Class Fall 2022 Membro de Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 18
Duração total: 123
