Ir para o conteúdo principal
Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement
O que você precisa
  1. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Base Cover: passo 1, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Base Cover: passo 1, imagem 2 %32
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 2, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 2, imagem 2 %32
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 3, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 3, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 3, imagem 3 %32
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 4, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 4, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 4, imagem 3 %32
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Wireless Card (NIC): passo 5, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Wireless Card (NIC): passo 5, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Wireless Card (NIC): passo 5, imagem 3 %32
    • Remove the screw holding down the small bracket for the wireless card using a Phillips #0 screwdriver.
    • Remove the black wired connection from the port over the black triangle.
    • Remove the wire with the white marking from the port above the white triangle.
    • Pull the Wi-Fi card out of its slot.
  6. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Fan: passo 6, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Fan: passo 6, imagem 2 %32
    • Gently remove the I/O cable.
  7. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 7, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 7, imagem 2 %32
    • Remove the fan cable from the motherboard.
  8. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 8, imagem 1 %32
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  9. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 9, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 9, imagem 2 %32
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
  10. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Heatsink: passo 10, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Heatsink: passo 10, imagem 2 %32
    • Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
  11. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 11, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 11, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 11, imagem 3 %32
    • Lift the heatsink off the motherboard.
  12. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Display Assembly: passo 12, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Display Assembly: passo 12, imagem 2 %32
    • Ensure that you have your device opened flat at a 180 degree angle. This will make removal easier.
  13. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 13, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 13, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 13, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Locate the ribbon cables for the assembly on the right hand side marked "MB1" and "MB2."
    • The "MB1" ribbon is locked with a copper/brass colored handle that must be lifted upwards. Then you can remove the ribbon by pulling it away from the socket.
    • The "MB2" ribbon is locked in its socket with a black latch. Using a non-metallic precision tool (such as tweezers) lift the latch and pull away the MB2 cable.
  14. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 14, imagem 1 %32
    • Remove the two screws holding down the assembly on the right hand area using a Phillips #00 screwdriver.
  15. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 15, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 15, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 15, imagem 3 %32
    • Remove the screw protecting the endpoints of the NIC cables and NIC chip using a Phillips #0 screwdriver.
    • Gently pull away the cabling from the NIC chip.
    • The wires can be removed without removing the heat sink, though this is not advised if you are not familiar with the layout.
  16. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 16, imagem 1 %32
    • Remove the two screws holding down the bracket of the assembly on the left hand side using a Phillips #0 screwdriver.
  17. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 17, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement: passo 17, imagem 2 %32
    • Lift the display assembly upwards away from the palm/main assembly.
  18. Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Charging Port: passo 18, imagem 1 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Charging Port: passo 18, imagem 2 %32 Dell Inspiron 17" 7786 2-in-1 Charging Port Replacement, Charging Port: passo 18, imagem 3 %32
    • Remove the single 3 mm screw that secures the port using a Phillips #0 screwdriver.
    • Disconnect the cable from the port by gently wiggling and pushing the plug away from the port.
    • Pull the disconnected cable upwards, and the rest of the power port will follow.
Conclusão
Antonio Franco
Membro desde: 08/25/22
1.025 Reputação
Autoria de 10 guias
Equipe
Gateway, Team 1-3, Class Fall 2022 Membro de Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 Membros
Autoria de 15 guias
Um comentário
Will this work on an Inspiron 14 2-in-1 7425?
Gertrude - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 39
Ao todo: 1,242
