Introdução
An alternative solution to this repair would to buy an Ethernet cable and connect one end of the cable to the OUTPUT of your router directly to your laptop. This removes the wireless portion of the computer and directly sends data through the cable allowing internet access.
O que você precisa
Remove the three black 6mm PH1 screws that anchor the hard drive.
This screw hole will be empty because the 15mm silver screw that holds the plastic cover will anchor the hard drive down when completely reassembled.
