Ir para o conteúdo principal
Dell Inspiron 17-7746 Battery Replacement
O que você precisa
  1. Dell Inspiron 17-7746 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Disconnect the laptop from the AC adapter and turn off the laptop.
  2. Dell Inspiron 17-7746 Battery Replacement: passo 2, imagem 1 %32
    • Place the laptop so the bottom faces up.
  3. Dell Inspiron 17-7746 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 17-7746 Battery Replacement: passo 3, imagem 2 %32 Dell Inspiron 17-7746 Battery Replacement: passo 3, imagem 3 %32
    • Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery.
    • Remove the 8mm PH 1 screw that holds the plastic cover in place over the battery.
    • Keep the screws together because the length of the screws will matter when you reassemble.
  4. Dell Inspiron 17-7746 Battery Replacement: passo 4, imagem 1 %32
    • Using the metal jimmy, pry up the first half of the cover.
  5. Dell Inspiron 17-7746 Battery Replacement: passo 5, imagem 1 %32
    • Apply pressure with your fingertips on top of the cover and drag toward the front of the laptop. This will make the plate slide off exposing the hard drive.
  6. Dell Inspiron 17-7746 Battery Replacement: passo 6, imagem 1 %32 Dell Inspiron 17-7746 Battery Replacement: passo 6, imagem 2 %32
    • Remove the two black PH1 6mm screws that anchor the battery.
  7. Dell Inspiron 17-7746 Battery Replacement: passo 7, imagem 1 %32
    • Grab the black tab on the battery with index finger and thumb.
    • If the Tab is broken or missing, use the plastic spudger to pry the battery out far enough to grab the battery by hand.
    • Avoid applying too much pressure on the battery with the plastic spudger. It might puncture the battery.
  8. Dell Inspiron 17-7746 Battery Replacement: passo 8, imagem 1 %32
    • Pull upwards, removing the battery from the laptop.
    • Ensure replacement battery has no bulging or has no cracks and lies flat in its location.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 1,520
