Ir para o conteúdo principal
Dell Inspiron 17-7737 Battery Replacement
O que você precisa
  1. Dell Inspiron 17-7737 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 17-7737 Battery Replacement: passo 2, imagem 2 %32 Dell Inspiron 17-7737 Battery Replacement: passo 2, imagem 3 %32
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Battery Replacement: passo 3, imagem 1 %32
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 17-7737 Battery Replacement: passo 4, imagem 2 %32
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
Conclusão
Mark Batista
Membro desde: 03/16/23
457 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 Membro de UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G7
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 34
Duração total: 267
