Ir para o conteúdo principal
Dell Inspiron 17-5755 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 17-5755 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 17-5755 Keyboard Replacement: passo 2, imagem 2 %32
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Keyboard Replacement: passo 3, imagem 1 %32
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Keyboard Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Keyboard Replacement: passo 6, imagem 1 %32 Dell Inspiron 17-5755 Keyboard Replacement: passo 6, imagem 2 %32
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Keyboard Replacement: passo 7, imagem 1 %32 Dell Inspiron 17-5755 Keyboard Replacement: passo 7, imagem 2 %32 Dell Inspiron 17-5755 Keyboard Replacement: passo 7, imagem 3 %32
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Keyboard Replacement: passo 8, imagem 1 %32 Dell Inspiron 17-5755 Keyboard Replacement: passo 8, imagem 2 %32 Dell Inspiron 17-5755 Keyboard Replacement: passo 8, imagem 3 %32
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Keyboard Replacement: passo 9, imagem 1 %32 Dell Inspiron 17-5755 Keyboard Replacement: passo 9, imagem 2 %32
    • Now that the keyboard is detached from the laptop, you may safely remove it.
Conclusão
Gabriel Espinal
Membro desde: 02/15/17
215 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S6-G1, Lacy Spring 2017 Membro de USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 720
