Ir para o conteúdo principal
Dell Inspiron 17-5755 Display Panel Replacement
O que você precisa
  1. Dell Inspiron 17-5755 Display Panel Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Display Panel Replacement: passo 2, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 2, imagem 2 %32
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Display Panel Replacement: passo 3, imagem 1 %32
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Display Panel Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement, Keyboard: passo 4, imagem 2 %32
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Display Panel Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Display Panel Replacement: passo 6, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 6, imagem 2 %32
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Display Panel Replacement: passo 7, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 7, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 7, imagem 3 %32
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Display Panel Replacement: passo 8, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 8, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 8, imagem 3 %32
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Display Panel Replacement: passo 9, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 9, imagem 2 %32
    • Now that the keyboard is detached from the laptop, you may safely remove it.
  10. Dell Inspiron 17-5755 Display Panel Replacement, Motherboard: passo 10, imagem 1 %32
    • Use a Phillips #0 screwdriver to unscrew the two 8mm screws which secure the base cover.
  11. Dell Inspiron 17-5755 Display Panel Replacement: passo 11, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 11, imagem 2 %32
    • Locate the tabs that hold the base cover to the laptop and use a plastic opening tool to gently release the base cover.
  12. Dell Inspiron 17-5755 Display Panel Replacement: passo 12, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 12, imagem 2 %32
    • Now with the base cover removed, you may lift it off of the laptop and continue.
  13. Dell Inspiron 17-5755 Display Panel Replacement: passo 13, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 13, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 13, imagem 3 %32
    • Disconnect the hard drive ribbon cable from the laptop by lifting the latch which secures it.
  14. Dell Inspiron 17-5755 Display Panel Replacement: passo 14, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the four 8mm screws which secure the hard drive assembly to the laptop.
  15. Dell Inspiron 17-5755 Display Panel Replacement: passo 15, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 15, imagem 2 %32
    • Carefully remove the hard drive and its assembly from the laptop.
  16. Dell Inspiron 17-5755 Display Panel Replacement: passo 16, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 16, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 16, imagem 3 %32
    • Remove the 3mm screw which secures the wireless card bracket.
    • After removing the screw, remove the wireless card bracket, along with the antenna cables secured to the wireless card.
    • Afterwards, you may slide and remove the wireless card from the motherboard.
  17. Dell Inspiron 17-5755 Display Panel Replacement: passo 17, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 17, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 17, imagem 3 %32
    • Gently spread apart the securing clips on each end of the memory-module slot until the memory module pops out.
    • Slide and remove the memory module afterwards.
  18. Dell Inspiron 17-5755 Display Panel Replacement: passo 18, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 18, imagem 2 %32
    • Use a plastic opening tool to gently pry the CMOS battery found at the bottom right of the laptop out of the socket.
  19. Dell Inspiron 17-5755 Display Panel Replacement: passo 19, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 19, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 19, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the 3mm screw which secures the optical-drive assembly to the computer base
    • Turn the computer over and using a plastic opening tool, push the optical-drive assembly out of the optical drive bay.
    • Afterwards, safely pull the optical-drive assembly out of the optical-drive bay.
  20. Dell Inspiron 17-5755 Display Panel Replacement: passo 20, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 20, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 20, imagem 3 %32
    • Lift the latch securing the optical drive ribbon cable, and disconnect it from the motherboard.
    • Afterwards, use a Phillips #0 screwdriver to remove the four 5mm screws.
  21. Dell Inspiron 17-5755 Display Panel Replacement: passo 21, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 21, imagem 2 %32
    • Turn over the laptop, and safely disconnect the speaker cable.
  22. Dell Inspiron 17-5755 Display Panel Replacement: passo 22, imagem 1 %32
    • Remove the antenna cables from the routing guides on the computer base.
  23. Dell Inspiron 17-5755 Display Panel Replacement: passo 23, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 23, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 15 screws that secure the computer base to the palm rest assembly.
    • Afterwards, safely pry the computer base from the palm rest assembly using a plastic opening tool.
    • There are 3 different screws used: Three 2mm screws on the edge of the optical drive, two 3mm screws located where the battery was, and ten 8mm screws.
  24. Dell Inspiron 17-5755 Display Panel Replacement: passo 24, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 24, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 5mm screw that secures the I/O board to the palm-rest assembly.
  25. Dell Inspiron 17-5755 Display Panel Replacement: passo 25, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 25, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 25, imagem 3 %32
    • Lift the I/O board and turn it over.
    • Afterwards, lift the ZIF latch and disconnect the I/O-board cable from the I/O board.
  26. Dell Inspiron 17-5755 Display Panel Replacement: passo 26, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 26, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 26, imagem 3 %32
    • Disconnect the fan cable from the motherboard.
    • Use a Phillips #0 screwdriver to remove the heat-sink screws in sequential order, as indicated by the numbers on the heat-sink assembly.
    • Afterwards lift the heat-sink assembly off the motherboard.
  27. Dell Inspiron 17-5755 Display Panel Replacement: passo 27, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 27, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 27, imagem 3 %32
    • Turn the computer over and open the display as far as possible.
    • Lift the latches for the power button board cable and disconnect it along with the touchpad cable from the motherboard.
  28. Dell Inspiron 17-5755 Display Panel Replacement: passo 28, imagem 1 %32
    • Close the display and turn the computer over.
    • Proceed to lift the latch which secures the ZIF display cable to the motherboard.
    • Disconnect the display cable from the motherboard.
  29. Dell Inspiron 17-5755 Display Panel Replacement: passo 29, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 29, imagem 2 %32
    • Use a Phillips# 0 screwdriver to remove the 3mm screw that secures the motherboard to the palm-rest assembly.
    • Afterwards, carefully peel the I/O board cable off the palm-rest assembly.
  30. Dell Inspiron 17-5755 Display Panel Replacement: passo 30, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 30, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 30, imagem 3 %32
    • Turn the motherboard over.
    • Lift the latch to disconnect the I/O-board cable from the motherboard.
  31. Dell Inspiron 17-5755 Display Panel Replacement: passo 31, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 31, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 31, imagem 3 %32
    • Disconnect the power-adapter port cable from the motherboard.
    • Afterwards you may safely remove the motherboard from the laptop.
  32. Dell Inspiron 17-5755 Display Panel Replacement, Display Panel: passo 32, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement, Display Panel: passo 32, imagem 2 %32
    • Using a Phillips 0 screwdriver, remove the screw (M2 x 3) the power-adapter port to the palm-rest assembly.
    • Peel off the tape that secures the power-adapter port to the palm-rest assembly.
  33. Dell Inspiron 17-5755 Display Panel Replacement: passo 33, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 33, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 33, imagem 3 %32
    • Carefully detach the antenna cables from their respective routing guides
  34. Dell Inspiron 17-5755 Display Panel Replacement: passo 34, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 34, imagem 2 %32
    • Using a Phillips 0 screwdriver, remove the 7 screws (M2.5 x 5) that secure the display hinges to the palm-rest assembly.
    • Detach the display assembly from the palm rest assembly
  35. Dell Inspiron 17-5755 Display Panel Replacement: passo 35, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 35, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 35, imagem 3 %32
    • Using the tip of your fingers, gently pry off the display bezel from the back-cover
  36. Dell Inspiron 17-5755 Display Panel Replacement: passo 36, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 36, imagem 2 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 36, imagem 3 %32
    • Using a Phillips 0 screwdriver, remove the 10 screws (M2.5 x 4.5) that secure the display panel to the display back-cover.
  37. Dell Inspiron 17-5755 Display Panel Replacement: passo 37, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 37, imagem 2 %32
    • Using a Phillips 0 screwdriver, remove the 6 screws (M2 x 3) that secure the display hinges to the display panel.
  38. Dell Inspiron 17-5755 Display Panel Replacement: passo 38, imagem 1 %32 Dell Inspiron 17-5755 Display Panel Replacement: passo 38, imagem 2 %32
    • Carefully turn the display assembly around.
    • Gently peel the display cable and disconnect the latch that is found under it.
  39. Dell Inspiron 17-5755 Display Panel Replacement: passo 39, imagem 1 %32
    • Once the display hinges are removed, your display panel is now ready to be replaced.
Conclusão
Uma outra pessoa concluiu este guia.
Jeff
Membro desde: 02/15/17
385 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S6-G1, Lacy Spring 2017 Membro de USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,151
