Ir para o conteúdo principal
Dell Inspiron 17-5749 Wireless Card Replacement
O que você precisa
  1. Dell Inspiron 17-5749 Wireless Card Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 17-5749 Wireless Card Replacement, Battery: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Wireless Card Replacement: passo 2, imagem 1 %32 Dell Inspiron 17-5749 Wireless Card Replacement: passo 2, imagem 2 %32
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Wireless Card Replacement, Back Cover: passo 3, imagem 1 %32 Dell Inspiron 17-5749 Wireless Card Replacement, Back Cover: passo 3, imagem 2 %32 Dell Inspiron 17-5749 Wireless Card Replacement, Back Cover: passo 3, imagem 3 %32
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Wireless Card Replacement, Wireless Card: passo 4, imagem 1 %32 Dell Inspiron 17-5749 Wireless Card Replacement, Wireless Card: passo 4, imagem 2 %32 Dell Inspiron 17-5749 Wireless Card Replacement, Wireless Card: passo 4, imagem 3 %32
    • Disconnect the antenna cables from the wireless card.
    • Push the securing tab to release the wireless card.
    • Slide the wireless card out of the wireless-card slot.
Conclusão
Christopher Tran
Membro desde: 02/13/18
1.161 Reputação
Autoria de 12 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 257
