Ir para o conteúdo principal
Dell Inspiron 17-5749 Optical Drive Replacement
O que você precisa
  1. Dell Inspiron 17-5749 Optical Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 17-5749 Optical Drive Replacement, Battery: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Optical Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 17-5749 Optical Drive Replacement: passo 2, imagem 2 %32
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32 Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: passo 3, imagem 2 %32 Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: passo 3, imagem 3 %32
    • Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
    • Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
  4. Dell Inspiron 17-5749 Optical Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron 17-5749 Optical Drive Replacement: passo 4, imagem 2 %32 Dell Inspiron 17-5749 Optical Drive Replacement: passo 4, imagem 3 %32
    • This step is only needed if replacing the optical drive.
    • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
    • Remove the optical-drive bracket from the optical-drive assembly.
    • Carefully pull the optical-drive bezel and remove it from the optical drive.
Conclusão
Christopher Tran
Membro desde: 02/13/18
1.162 Reputação
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 183
