Ir para o conteúdo principal
Dell Inspiron 17-5749 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 17-5749 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 17-5749 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 17-5749 Keyboard Replacement: passo 2, imagem 2 %32
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  4. Dell Inspiron 17-5749 Keyboard Replacement: passo 4, imagem 1 %32
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
Conclusão
Christopher Tran
Membro desde: 02/13/18
1.161 Reputação
Autoria de 12 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 27
Duração total: 453
