Ir para o conteúdo principal
Dell Inspiron 17-5748 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 17-5748 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Keyboard Replacement: passo 3, imagem 1 %32
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Open the laptop and locate the keyboard.
  5. Dell Inspiron 17-5748 Keyboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 17-5748 Keyboard Replacement: passo 5, imagem 2 %32
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  6. Dell Inspiron 17-5748 Keyboard Replacement: passo 6, imagem 1 %32 Dell Inspiron 17-5748 Keyboard Replacement: passo 6, imagem 2 %32
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  7. Dell Inspiron 17-5748 Keyboard Replacement: passo 7, imagem 1 %32 Dell Inspiron 17-5748 Keyboard Replacement: passo 7, imagem 2 %32
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
Conclusão
Justine Vaca
Membro desde: 02/12/18
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 668
