Ir para o conteúdo principal
Dell Inspiron 17-3721 Optical Drive Replacement
O que você precisa
  1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: passo 1, imagem 1 %32 Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: passo 1, imagem 2 %32
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Optical Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 17-3721 Optical Drive Replacement: passo 2, imagem 2 %32
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: passo 3, imagem 2 %32 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: passo 3, imagem 3 %32
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Optical Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron 17-3721 Optical Drive Replacement: passo 4, imagem 2 %32 Dell Inspiron 17-3721 Optical Drive Replacement: passo 4, imagem 3 %32
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Kevin Prairie
Membro desde: 03/20/18
445 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S5-G3, Peak Spring 2018 Membro de UMass Dartmouth, Team S5-G3, Peak Spring 2018
UMASSD-PEAK-S18S5G3
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 325
