Ir para o conteúdo principal
Dell Inspiron 17-3721 Fan Replacement
O que você precisa
  1. Dell Inspiron 17-3721 Fan Replacement, Keyboard: passo 1, imagem 1 %32 Dell Inspiron 17-3721 Fan Replacement, Keyboard: passo 1, imagem 2 %32
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Fan Replacement: passo 2, imagem 1 %32 Dell Inspiron 17-3721 Fan Replacement: passo 2, imagem 2 %32
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Fan Replacement, Optical Drive: passo 3, imagem 1 %32 Dell Inspiron 17-3721 Fan Replacement, Optical Drive: passo 3, imagem 2 %32 Dell Inspiron 17-3721 Fan Replacement, Optical Drive: passo 3, imagem 3 %32
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Fan Replacement: passo 4, imagem 1 %32 Dell Inspiron 17-3721 Fan Replacement: passo 4, imagem 2 %32 Dell Inspiron 17-3721 Fan Replacement: passo 4, imagem 3 %32
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
  5. Dell Inspiron 17-3721 Fan Replacement, Fan: passo 5, imagem 1 %32
    • Remove the seven 6mm PH1 Philips head screws from the motherboard.
    • There may be more or less screws in your motherboard as the laptops do vary.
  6. Dell Inspiron 17-3721 Fan Replacement: passo 6, imagem 1 %32 Dell Inspiron 17-3721 Fan Replacement: passo 6, imagem 2 %32
    • Located on the lower left of the motherboard, disconnect the wire that connects the speaker by pushing it or pulling it away from the white box.
  7. Dell Inspiron 17-3721 Fan Replacement: passo 7, imagem 1 %32
    • Located on the lower right of the motherboard, flip up the black hatch and remove the ribbon cable by gently tugging it outwards.
    • Ribbon cables are very fragile and can tear easily. Handle with care.
  8. Dell Inspiron 17-3721 Fan Replacement: passo 8, imagem 1 %32
    • Remove the 4mm PH1 Philips screw to the right of the fan.
  9. Dell Inspiron 17-3721 Fan Replacement: passo 9, imagem 1 %32
    • Remove the 4mm PH1 Philips screw to the top of the fan.
  10. Dell Inspiron 17-3721 Fan Replacement: passo 10, imagem 1 %32
    • Remove the motherboard from the USB sockets to the left by first pulling the motherboard to the right and then flip the motherboard up against the screen.
  11. Dell Inspiron 17-3721 Fan Replacement: passo 11, imagem 1 %32
    • Located on the lower left, remove the 4mm PH1 Philips screw to the top of the fan.
  12. Dell Inspiron 17-3721 Fan Replacement: passo 12, imagem 1 %32 Dell Inspiron 17-3721 Fan Replacement: passo 12, imagem 2 %32
    • Remove the wire for the fan by pulling or pushing the white tab from the white box.
Conclusão
Kevin Prairie
Membro desde: 03/20/18
445 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S5-G3, Peak Spring 2018 Membro de UMass Dartmouth, Team S5-G3, Peak Spring 2018
UMASSD-PEAK-S18S5G3
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 990
