Ir para o conteúdo principal
Dell Inspiron 17 Laptop Battery Replacement
O que você precisa
  1. Dell Inspiron 17 Laptop Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before starting, make sure the laptop is powered off and disconnected from any power sources.
  2. Dell Inspiron 17 Laptop Battery Replacement: passo 2, imagem 1 %32
    • Remove the Screws of the Laptop with help screwdriver.
    • There are 6 screws to remove. Make Sure to open the back of the laptop delicately.
  3. Dell Inspiron 17 Laptop Battery Replacement: passo 3, imagem 1 %32
    • Carefully disconnect the old battery from the motherboard.
    • Gently remove the old battery from its housing by removing plug of battery.
  4. Dell Inspiron 17 Laptop Battery Replacement: passo 4, imagem 1 %32
    • Insert the new battery into the housing.
    • Connect the new battery to the motherboard.
    • Securely reattach the battery back cover.
  5. Dell Inspiron 17 Laptop Battery Replacement: passo 5, imagem 1 %32
    • Plug in the laptop and charge it to Full Capacity.
    • Power on the laptop and make sure it works with the new battery.
Conclusão
Anmol Desai
Membro desde: 09/14/23
178 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 61
Últimos 30 dias: 285
Duração total: 847
