Introdução
A laptop battery is a crucial component of the computer system. Acting as a source of power, the battery enables the laptop to run without a power cable, however, laptop batteries tend to degrade over time. As such, you may find that your Dell Inspiron 16-7610 heats up faster than it used to or that the computer's performance has worsened. Replacing the battery will resolve these issues. If you find your battery is swollen or damaged, be sure to take any necessary precautions to prevent injury.
O que você precisa
Flip the device over, so the backside is facing up.
Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
Use a Phillips #00 to remove the five screws securing the battery to the laptop.
Pull the bundled cable away from the connector in the same direction as the wires are running.
Use both hands to life the battery up and remove it from the laptop.
