Ir para o conteúdo principal
Dell Inspiron 16 7610 Back Case Replacement
O que você precisa
  1. Dell Inspiron 16 7610 Back Case Replacement, Back Case: passo 1, imagem 1 %32 Dell Inspiron 16 7610 Back Case Replacement, Back Case: passo 1, imagem 2 %32
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove seven 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
  2. Dell Inspiron 16 7610 Back Case Replacement: passo 2, imagem 1 %32
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
Conclusão
Jerson Gomez
Membro desde: 02/02/23
877 Reputação
Autoria de 3 guias
Equipe
Gateway, Team 1-3, Pee Spring 2023 Membro de Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
Membros da 4
Autoria de 6 guias
Um comentário
Followed instructions. No clips broken but still cannot close the back cover. There’s a small gab in between the mouse and the cover when I close it.
Enos Nii Armah - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 453
