Ir para o conteúdo principal
Dell Inspiron 15z 1570 Memory Modules Replacement
O que você precisa
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  1. Dell Inspiron 15z 1570 Memory Modules Replacement, Popping up the Memory Modules: passo 2, imagem 1 %32 Dell Inspiron 15z 1570 Memory Modules Replacement, Popping up the Memory Modules: passo 2, imagem 2 %32
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  2. Dell Inspiron 15z 1570 Memory Modules Replacement, Align the Notch: passo 3, imagem 1 %32 Dell Inspiron 15z 1570 Memory Modules Replacement, Align the Notch: passo 3, imagem 2 %32
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  3. Dell Inspiron 15z 1570 Memory Modules Replacement, Sliding the Memory Module: passo 4, imagem 1 %32
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 53
