Introdução
In this guide, we will be showing you how to remove and replace the Display Assembly.
Peças
Não são necessárias peças.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin. CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Remove the two screws on the base of the computer that secure the display assembly to the computer base.
  2. Disconnect the display cable and remove the screw from the system board. Disconnect the display cable and remove the screw from the system board.
    • Disconnect the display cable and remove the screw from the system board.
  3. Pull the Mini-Card antenna cables up through the slot in the computer base.
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Note the routing of all the cables and remove them from their routing guides.
    • Note the routing of all the cables and remove them from their routing guides.
  5. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  6. Hold the display while you remove the three screws that secure the display assembly to the computer base.
    • Hold the display while you remove the three screws that secure the display assembly to the computer base.
  7. Lift and remove the display assembly from the computer base.
    • Lift and remove the display assembly from the computer base.
  8. Using the alignment posts, place the display assembly in position and replace the three screws that secure the display assembly to the computer base.
    • Using the alignment posts, place the display assembly in position and replace the three screws that secure the display assembly to the computer base.
  9. Route the Mini-Card antenna cables and display cable through their routing guides.
    • Route the Mini-Card antenna cables and display cable through their routing guides.
  10. Route the antenna cables through the slot in the computer base.
    • Route the antenna cables through the slot in the computer base.
  11. Replace the screw and connect the display cable.
    • Replace the screw and connect the display cable.
Linha de Chegada
Terrence15
70.274 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 11
