Ir para o conteúdo principal
Dell Inspiron 15R Screen Replacement
O que você precisa
  1. Dell Inspiron 15R Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device over and locate the battery.
  2. Dell Inspiron 15R Screen Replacement: passo 2, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 2, imagem 2 %32
    • Place thumbs on each latch and push outwards.
  3. Dell Inspiron 15R Screen Replacement: passo 3, imagem 1 %32
    • Push and slide the battery away from you.
  4. Dell Inspiron 15R Screen Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron 15R Screen Replacement, Keyboard: passo 4, imagem 2 %32 Dell Inspiron 15R Screen Replacement, Keyboard: passo 4, imagem 3 %32
    • Locate the RAM compartment and the screw on the right hand side. Remove the cover.
  5. Dell Inspiron 15R Screen Replacement: passo 5, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 5, imagem 2 %32
    • Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
  6. Dell Inspiron 15R Screen Replacement: passo 6, imagem 1 %32
    • Turn the device around and open it up.
  7. Dell Inspiron 15R Screen Replacement: passo 7, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 7, imagem 2 %32
    • Using your index finger, push down on the F1 and F7 keys.
  8. Dell Inspiron 15R Screen Replacement: passo 8, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 8, imagem 2 %32
    • Using your index finger, push down on the x icon and Home keys.
  9. Dell Inspiron 15R Screen Replacement: passo 9, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 9, imagem 2 %32 Dell Inspiron 15R Screen Replacement: passo 9, imagem 3 %32
    • Locate the keyboard lining (between the black and silver).
    • Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
  10. Dell Inspiron 15R Screen Replacement: passo 10, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 10, imagem 2 %32
    • Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
  11. Dell Inspiron 15R Screen Replacement: passo 11, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 11, imagem 2 %32
    • Carefully pull and turn the keyboard over.
  12. Dell Inspiron 15R Screen Replacement: passo 12, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 12, imagem 2 %32
    • Lift the black lever.
  13. Dell Inspiron 15R Screen Replacement: passo 13, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 13, imagem 2 %32
    • Remove the keyboard cable
  14. Dell Inspiron 15R Screen Replacement, Hard Drive: passo 14, imagem 1 %32 Dell Inspiron 15R Screen Replacement, Hard Drive: passo 14, imagem 2 %32
    • Turn laptop over and remove the bottom four screw covers outlined in red.
    • Then remove the three base screws.
  15. Dell Inspiron 15R Screen Replacement: passo 15, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 15, imagem 2 %32
    • Turn laptop over and open it. Locate and remove the five palm rest screws.
  16. Dell Inspiron 15R Screen Replacement: passo 16, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 16, imagem 2 %32 Dell Inspiron 15R Screen Replacement: passo 16, imagem 3 %32
    • Locate the palm rest cables. Lift the black levers and unplug the blue cables.
  17. Dell Inspiron 15R Screen Replacement: passo 17, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 17, imagem 2 %32
    • Lift the palm rest until it snaps off.
  18. Dell Inspiron 15R Screen Replacement: passo 18, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 18, imagem 2 %32
    • Close cover and turn laptop over. Locate and remove the four hard drive screws.
  19. Dell Inspiron 15R Screen Replacement: passo 19, imagem 1 %32
  20. Dell Inspiron 15R Screen Replacement: passo 20, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 20, imagem 2 %32 Dell Inspiron 15R Screen Replacement: passo 20, imagem 3 %32
    • Lift and remove the hard drive.
  21. Dell Inspiron 15R Screen Replacement: passo 21, imagem 1 %32
    • Remove the hard drive connector.
  22. Dell Inspiron 15R Screen Replacement, Screen: passo 22, imagem 1 %32 Dell Inspiron 15R Screen Replacement, Screen: passo 22, imagem 2 %32
    • Locate and remove the bottom hinge screws.
  23. Dell Inspiron 15R Screen Replacement: passo 23, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 23, imagem 2 %32 Dell Inspiron 15R Screen Replacement: passo 23, imagem 3 %32
    • Turn laptop over and open it. Locate and unplug the LCD Cable.
  24. Dell Inspiron 15R Screen Replacement: passo 24, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 24, imagem 2 %32 Dell Inspiron 15R Screen Replacement: passo 24, imagem 3 %32
    • Unplug the black and white wires on the wireless antenna.
  25. Dell Inspiron 15R Screen Replacement: passo 25, imagem 1 %32 Dell Inspiron 15R Screen Replacement: passo 25, imagem 2 %32 Dell Inspiron 15R Screen Replacement: passo 25, imagem 3 %32
    • Remove the two hinge screws on both the left and right hand side.
  26. Dell Inspiron 15R Screen Replacement: passo 26, imagem 1 %32
    • Remove the screen.
Conclusão
Trixie Gonzalez
Membro desde: 02/14/15
843 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 2,548
