Ir para o conteúdo principal
Dell Inspiron 15R SE 7520 Memory Module Replacement
  1. Dell Inspiron 15R SE 7520 Memory Module Replacement, Popping up the Memory Module: passo 1, imagem 1 %32 Dell Inspiron 15R SE 7520 Memory Module Replacement, Popping up the Memory Module: passo 1, imagem 2 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 15R SE 7520 Memory Module Replacement, Remove the Memory Module: passo 2, imagem 1 %32
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 15R SE 7520 Memory Module Replacement, Align the Notch: passo 3, imagem 1 %32 Dell Inspiron 15R SE 7520 Memory Module Replacement, Align the Notch: passo 3, imagem 2 %32
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Inspiron 15R SE 7520 Memory Module Replacement, Sliding the Memory Module: passo 4, imagem 1 %32
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 229
