Ir para o conteúdo principal
Dell Inspiron 15R SE 7520 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Sliding the Hard Drive: passo 2, imagem 1 %32
    • Using the pull-tab, slide the hard-drive assembly toward the back of the computer to disconnect the hard-drive assembly from the connector on the system board.
  3. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 3, imagem 1 %32
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Lifting the Hard Drive: passo 5, imagem 1 %32 Dell Inspiron 15R SE 7520 Hard Drive Replacement, Lifting the Hard Drive: passo 5, imagem 2 %32
    • Lift the hard drive off the hard-drive bracket.
  6. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Align the Screw Holes: passo 6, imagem 1 %32
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Place the Hard-Drive Assembly: passo 8, imagem 1 %32
    • Place the hard-drive assembly on the computer base.
  9. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Sliding the Hard Drive Assembly: passo 9, imagem 1 %32
    • Using the pull-tab, slide the hard-drive assembly toward the front of the computer, to connect the hard-drive assembly to the connector on the system board.
  10. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the computer base.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.309 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.984 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,028
