Ir para o conteúdo principal
Dell Inspiron 15R SE 7520 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Disconnecting the Antenna Cables: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Disconnect the antenna cables from the connectors on the Mini-Card.
  2. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Peel the Tape: passo 2, imagem 1 %32
    • Peel the tape that secures the display cable to the system board and then disconnect the display cable from the connector on the system board.
  3. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Display Cable Routing: passo 3, imagem 1 %32
    • Make a note of the display cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the display assembly to the computer base.
  5. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Lifting the Display Assembly: passo 5, imagem 1 %32
    • Lift the display assembly off the computer base.
  6. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Placing the Display Assembly: passo 6, imagem 1 %32
    • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
  7. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Route the Display Cable: passo 7, imagem 1 %32
    • Route the display cable through the routing guides and connect the display cable to the connector on the system board.
  8. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Adhering the Tape: passo 8, imagem 1 %32
    • Adhere the tape that secures the display cable to the system board.
  9. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Connecting the Antenna Cables: passo 9, imagem 1 %32
    • Connect the antenna cables to the connectors on the Mini-Card.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 748
