Introdução
In this guide, we will be showing you how to remove and replace the Display Assembly.
O que você precisa
Disconnect the antenna cables from the connectors on the Mini-Card.
Peel the tape that secures the display cable to the system board and then disconnect the display cable from the connector on the system board.
Make a note of the display cable routing and remove the cable from the routing guides.
Remove the screws that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
Route the display cable through the routing guides and connect the display cable to the connector on the system board.
Adhere the tape that secures the display cable to the system board.
Connect the antenna cables to the connectors on the Mini-Card.
Uma outra pessoa concluiu este guia.
