Ir para o conteúdo principal
Dell Inspiron 15R N5110 Memory Module Replacement
O que você precisa
  1. Dell Inspiron 15R N5110 Memory Module Replacement, Loosen the Screw: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 15R N5110 Memory Module Replacement, Lifting the Memory Module Cover: passo 2, imagem 1 %32
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Dell Inspiron 15R N5110 Memory Module Replacement, Popping up the Memory Module: passo 3, imagem 1 %32 Dell Inspiron 15R N5110 Memory Module Replacement, Popping up the Memory Module: passo 3, imagem 2 %32
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Dell Inspiron 15R N5110 Memory Module Replacement, Remove the Memory Module: passo 4, imagem 1 %32
    • Remove the memory module from the memory-module connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  5. Dell Inspiron 15R N5110 Memory Module Replacement, Sliding the Memory Module: passo 6, imagem 1 %32
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  6. Dell Inspiron 15R N5110 Memory Module Replacement, Slide the Tabs: passo 7, imagem 1 %32
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  7. Dell Inspiron 15R N5110 Memory Module Replacement, Tighten the Screw: passo 8, imagem 1 %32
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 354
