Ir para o conteúdo principal
Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement
O que você precisa
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Sliding the Hard Drive Assembly: passo 3, imagem 1 %32
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  3. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Lifting the Hard Drive Assembly: passo 4, imagem 1 %32
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Remove the Screws: passo 5, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Lifting the Hard-Drive Bracket: passo 6, imagem 1 %32
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Align the Screw Holes: passo 7, imagem 1 %32
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Replace the Screws: passo 8, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Placing the Hard Drive Assembly: passo 9, imagem 1 %32
    • Slide and place the hard-drive assembly in the hard-drive bay.
  9. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: passo 10, imagem 1 %32
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  10. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Replace the Screws: passo 11, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the computer base.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.091 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 638
