Ir para o conteúdo principal
Dell Inspiron 15R Keyboard Replacement
O que você precisa
  1. Dell Inspiron 15R Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device over and locate the battery.
  2. Dell Inspiron 15R Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement: passo 2, imagem 2 %32
    • Place thumbs on each latch and push outwards.
  3. Dell Inspiron 15R Keyboard Replacement: passo 3, imagem 1 %32
    • Push and slide the battery away from you.
  4. Dell Inspiron 15R Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Dell Inspiron 15R Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Locate the RAM compartment and the screw on the right hand side. Remove the cover.
  5. Dell Inspiron 15R Keyboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement: passo 5, imagem 2 %32
    • Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
  6. Dell Inspiron 15R Keyboard Replacement: passo 6, imagem 1 %32
    • Turn the device around and open it up.
  7. Dell Inspiron 15R Keyboard Replacement: passo 7, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement: passo 7, imagem 2 %32
    • Using your index finger, push down on the F1 and F7 keys.
  8. Dell Inspiron 15R Keyboard Replacement: passo 8, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement: passo 8, imagem 2 %32
    • Using your index finger, push down on the x icon and Home keys.
  9. Dell Inspiron 15R Keyboard Replacement: passo 9, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement: passo 9, imagem 2 %32 Dell Inspiron 15R Keyboard Replacement: passo 9, imagem 3 %32
    • Locate the keyboard lining (between the black and silver).
    • Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
  10. Dell Inspiron 15R Keyboard Replacement: passo 10, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement: passo 10, imagem 2 %32
    • Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
  11. Dell Inspiron 15R Keyboard Replacement: passo 11, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement: passo 11, imagem 2 %32
    • Carefully pull and turn the keyboard over.
  12. Dell Inspiron 15R Keyboard Replacement: passo 12, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement: passo 12, imagem 2 %32
    • Lift the black lever.
  13. Dell Inspiron 15R Keyboard Replacement: passo 13, imagem 1 %32 Dell Inspiron 15R Keyboard Replacement: passo 13, imagem 2 %32
    • Remove the keyboard cable
Conclusão
Uma outra pessoa concluiu este guia.
Trixie Gonzalez
Membro desde: 02/14/15
843 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,335
