Introdução
Demonstrating step-by-step this guide will show you how to replace your hard drive.
O que você precisa
Locate the RAM compartment and the screw on the right hand side. Remove the cover.
Turn laptop over and remove the bottom four screw covers outlined in red.
Then remove the three base screws.
4 outras pessoas executaram este guia.
Um comentário
Shoot! My Dell Inspiron 15R is different. Mine has an almost full length cover (11.6”) by 3” wide on the bottom. The hard drive and memory sticks are under that cover. I’m just not sure what else to remove to replace the drive with an SSD.
