Introdução
If your Dell Inspiron 15R 5537’s battery is not holding a charge or unable to be charged then your battery is most likely bad and needs to be replaced.
A properly functioning battery will supply your computer with ample charge to meet the range that was specified within the specs on the laptop. But after the battery has gone through a repeated amount of cycles it may begin to lose its ability to hold a charge. The first course of action would be to calibrate your battery and if the discharge rate is still really fast then a battery replacement might be the best option.
A damaged battery can be very dangerous and cause a fire. If you notice the casing of your battery is cracked or damaged in any way, take the necessary precautions.
O que você precisa
Close the display and turn over the computer to see the battery locking tabs.
