Introdução
In this guide, we will be showing you how to remove and replace the Memory Module.
Peças
Não são necessárias peças.
  1. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Using your fingertips, lift the memory-module cover out of the slots on the computer base.
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Remove the memory module from the memory-module connector.
    • Remove the memory module from the memory-module connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  6. Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  7. Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  8. Tighten the captive screw that secures the memory-module cover to the computer base.
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Linha de Chegada
Terrence15
70.653 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Todo: 23
