Ir para o conteúdo principal
Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement
O que você precisa
  1. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: passo 2, imagem 1 %32
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  3. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Assembly: passo 3, imagem 1 %32
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Bracket: passo 5, imagem 1 %32
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Align the Screw Holes: passo 6, imagem 1 %32
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: passo 8, imagem 1 %32
    • Slide and place the hard-drive assembly in the hard-drive bay.
  9. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: passo 9, imagem 1 %32
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  10. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the computer base.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 872
