Ir para o conteúdo principal
Dell Inspiron 15R 5520 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15R 5520 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip device on its back displaying the battery.
  2. Dell Inspiron 15R 5520 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 15R 5520 Hard Drive Replacement: passo 2, imagem 2 %32 Dell Inspiron 15R 5520 Hard Drive Replacement: passo 2, imagem 3 %32
    • Place a finger on both latches and push outwards.
    • Grab by the lip and pull upwards to remove battery.
  3. Dell Inspiron 15R 5520 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Dell Inspiron 15R 5520 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Locate and loosen the three 3 mm screws.
    • Remove the plastic casing with the screws attached.
  4. Dell Inspiron 15R 5520 Hard Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron 15R 5520 Hard Drive Replacement: passo 4, imagem 2 %32 Dell Inspiron 15R 5520 Hard Drive Replacement: passo 4, imagem 3 %32
    • Locate and remove the four 4mm screws holding the hard drive in place.
  5. Dell Inspiron 15R 5520 Hard Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron 15R 5520 Hard Drive Replacement: passo 5, imagem 2 %32 Dell Inspiron 15R 5520 Hard Drive Replacement: passo 5, imagem 3 %32
    • Push the hard drive horizontally and away from yourself.
  6. Dell Inspiron 15R 5520 Hard Drive Replacement: passo 6, imagem 1 %32 Dell Inspiron 15R 5520 Hard Drive Replacement: passo 6, imagem 2 %32
    • Lift the hard drive up and out of the bay.
Conclusão
3 outras pessoas executaram este guia.
zAj
Membro desde: 09/15/16
484 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 18-1, Blackwell Fall 2016 Membro de USF Tampa, Team 18-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G1
Membros da 3
Autoria de 5 guias
2 comentários
I have a Dell 15R 5537. The drive removal is about the same. There are only two screws holding the drive, though. They’re located at the back of the drive. Push the drive back to clear the connector and pull up aided by a clear plastic pull tab on the drive.
Adrian Kocurek - Responder
It worked and was well worth installing an SSD.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 2,355
