Introdução
The RAM on the Dell Inspiron 1564 laptop needs replacing over time. When there are source-demanding programs, the RAM is the first component to be maxed out which can tend to make your computer run slow. Use this guide to remove and replace the RAM.
O que você precisa
Locate the battery latch on the bottom of the computer and slide it to the right.
While holding the battery latch, pull the battery away from the device.
Quase terminado!
Conclusão
