Ir para o conteúdo principal
Dell Inspiron 1564 RAM Replacement
O que você precisa
  1. Dell Inspiron 1564 RAM Replacement, RAM: passo 1, imagem 1 %32 Dell Inspiron 1564 RAM Replacement, RAM: passo 1, imagem 2 %32
    • Locate the battery latch on the bottom of the computer and slide it to the right.
    • While holding the battery latch, pull the battery away from the device.
  2. Dell Inspiron 1564 RAM Replacement: passo 2, imagem 1 %32
    • With the Phillips #0 screwdriver, loosen the three screws from the cover behind the battery latch.
  3. Dell Inspiron 1564 RAM Replacement: passo 3, imagem 1 %32 Dell Inspiron 1564 RAM Replacement: passo 3, imagem 2 %32 Dell Inspiron 1564 RAM Replacement: passo 3, imagem 3 %32
    • Locate the RAM on the bottom of the computer.
    • Remove the RAM by gently pulling back the small clips along the side of the RAM, and lifting the RAM upwards so the RAM is now angled.
    • Pull the RAM away from the device.
    • Repeat the actions above for the second stick of RAM.
    • When reinstalling the RAM, put it back in at an angle in the socket, and make sure the RAM is audiblely clicked into place.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 982
