Ir para o conteúdo principal
Dell Inspiron 1564 Memory Module Replacement
  1. Dell Inspiron 1564 Memory Module Replacement, Popping up the Memory Module: passo 1, imagem 1 %32 Dell Inspiron 1564 Memory Module Replacement, Popping up the Memory Module: passo 1, imagem 2 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    Pergunte ao FixBot
  2. Dell Inspiron 1564 Memory Module Replacement, Remove the Memory Module: passo 2, imagem 1 %32
    • Remove the memory module from the memory module connector.
    Pergunte ao FixBot
  3. Dell Inspiron 1564 Memory Module Replacement, Align the Notch: passo 3, imagem 1 %32
    • Align the notch in the memory module with the tab in the memory module connector.
    Pergunte ao FixBot
  4. Dell Inspiron 1564 Memory Module Replacement, Sliding the Memory Module: passo 4, imagem 1 %32
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    Pergunte ao FixBot
Linha de Chegada
Terrence15
Membro desde: 12/18/17
80.125 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.002 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 33
Ao todo: 445
