Introdução
In this guide, we will be showing you how to remove and replace the Display Assembly.
O que você precisa
Note of the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
Pull the Mini-Card antenna cables up through the slot in the computer base.
Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
Hold the display assembly in place and remove the three screws that secure the display assembly to the computer base.
Lift the display assembly off the alignment posts on the computer base.
Use the alignment posts to place the display assembly on the computer base.
Replace the three screws that secure the display assembly to the computer base
Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
Route the Mini-Card antenna cables through the routing guides on the palm rest.
Thread the Mini-Card antenna cables through the slot in the computer base.
Turn the computer over and replace the two screws that secure the display assembly to the computer base.
